AutoCAD Architecture and AutoCAD MEP Anchorage tool to 3D Grid
jtm2020hyo
jtm2020hyo
I found a method to manage an entire project in AutoCAD Architecture and AutoCAD MEP and work similar to Revit, but is need to anchor Wall or Slab edges in 3D grid parametric object in all 3D grid faces.
bjXDGEo
anyone know how can I do this?
Gepaha
I never used it and I'm curious about the potential and limitations.
In a quick test using the anchor command it worked and the position and rotation adjustments of the wall in relation to the 3d grid layout can be made through the anchor dialog accessible by properties tab.
Anchor Wall to Layout Grid 3d CommandAnchor Wall to Layout Grid 3d CommandWall Anchor PositionWall Anchor Position
So I think it is also possible via .NET. I did a very simple test (I don't have time at the moment) and roughly speaking it is right. You need to position the walls, etc., but everything indicates that it is possible.
Look for AnchorEntityToLayoutNode and LayoutGrid3d.
jtm2020hyo
look nice, I did not notice that is possible to use an Anchor offset.
is there any method to link slabs, stairs, and column/beams with 3D Grid?
