AutoCAD 2023 - Visual Studio installation requirements
rberghLJ4SA
rberghLJ4SA
Hi All,
I am busy setting up a new machine to develop with AutoCAD 2023 OEM. Which version of visual studio is required and which component of visual studio do I need to install ?
Chuong.Ho
Let check to NET framework 4.8.
Chuong Ho
_gile
Have a look here:
Gilles Chanteau
GileCAD
GitHub
rberghLJ4SA
Thanks so much but unfortunately it doesn't specify required components.
For instance Visual C++ ATL is required component that isn't installed for basic C# installation
kerry_w_brown
I'm a little surprised that there is not more explicit detail here
https://www.autodesk.com/developer-network/platform-technologies/autocad-oem
Perhaps you could request a revision to the information shown.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
techsoft3d
There's an overview of the 2023 release requirements made by Madhu here: https://adndevblog.typepad.com/autocad/2022/04/autocad-2023-developer-update.html
The OEM platform requirements are identical.
Tech Soft 3D provides learning resources on their Developer Zone: https://developer.techsoft3d.com/platform-products/autocad_oem/training/
10 minutes into the video 'AutoCAD OEM Virtual Training: Basics of AutoCAD OEM' the .NET and C++ environment settings are explained for 2021 release, I'm sure you'll be able to figure it out for other releases and versions of Visual Studio.
Mark the reply as solution please, do others can find this information.
Paavo Rantanen, Tech Soft 3D
