AutoCAD 2016 GetAcadDocument throws exception
Message 1 of 9
The following code is used without any problems in AutoCAD 2015 but gives now an exception error on the GetAcadDocument function:
Public ReadOnly Property ThisDrawing As AcadDocument
 Get
  Dim tAcadDoc As ApplicationServices.Document
  Dim tAcadDocCOM As AcadDocument
  tAcadDoc = ApplicationServices.Application.DocumentManager.MdiActiveDocument
  tAcadDocCOM = CType(ApplicationServices.DocumentExtension.GetAcadDocument(tAcadDoc), AcadDocument)
  Return tAcadDocCOM
 End Get
End Property
I'm using the ObjectARX2015 library and .NetFramework v4.5
TIA for your help.
Regards Leo
Replies (8)
Message 2 of 9
Virupaksha_aithal
Autodesk Support
Autodesk Support
Can you please provide more details on this behavior like when it is happening? Also, make sure you verify whether you are getting MdiActiveDocument as null. There is always a chance that you get MdiActiveDocument null (because of non dwg window)
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
Message 3 of 9
For example, a drawing is active and I execute the command RH_Bhatch, as defined below. It goes wrong on the bold statement.
<CommandMethod("RH_Bhatch")> _
Sub RH_Bhatch()
  ThisDrawing.SendCommand("Hatch" & vbCr)
End Sub
Function ThisDrawing() As AcadDocument
  Return tAcadDocCOM
End Function
Message 4 of 9
Virupaksha_aithal
Autodesk Support
Autodesk Support
I am unable to reproduce the issue with code provide by you. At my end AutoCAD 2016 is able to start the hatch command.
Message 5 of 9
I'm using references to the ObjectARX2015. But I see there is a ObjectARX2016. Can this be the problem?
Regards Leo
Message 6 of 9
Virupaksha_aithal
Autodesk Support
Autodesk Support
referring from ObjectARX 2015 should not create any issues. Please make sure you refer your interops from ObjectARX SDK folder (Autodesk.AutoCAD.Interop.Common.dll & Autodesk.AutoCAD.Interop.dll).
Message 7 of 9
This are the references I'm using:
And this is the error:
Message 8 of 9
norman.yuan
Using older version of COP API (AutoCAD COM Interop) with newer version of AutoCAD, in your case, using 2015 COOM interop with AutoCAD 2016, should be OK in most cases.
My guess with your issue is because of the AutoCAD interop assembly being embeded in the project. Since VS2012, when a COM reference is added into VS project, VS set the "Embed Interop Type" to "True". This will causes conflict because AutoCAD2016 uses its own Com Interop coming with AutoCAD installation, while your code tries to use the embeded one, which is in different version.
So, make sure for the reference to AutoCAD Interop in Visual Studio, "Embed Interop Type" is set to "False" and "Copy Local" is also set to "False".
Norman Yuan
Drive CAD With Code
Message 9 of 9
When I do that for the Autodesk.AutoCAD.Interop.Common, I still get the same error.
When I do it also for Autodesk.AutoCAD.Interop I get the following error:
