Auto close dialog by default selection
milindnalgirkar
Message 1 of 9
milindnalgirkar
am using 'Autodesk.AutoCAD.Internal.Utils.CloseCommandLine();' as attached in Image1 for closing command line. But command waits for input and after 'enter' it prompts for confirmation dialog box. I need to close it without user input.
Replies (8)
Message 2 of 9
Alexander.Rivilis
This post can help you: http://adndevblog.typepad.com/autocad/2015/04/dismissing-popup-dialogs-in-autocad.html
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 9
Alexander.Rivilis
Other solution: https://adndevblog.typepad.com/autocad/2013/07/disable-task-dialogs-programmatically.html
Also read comments to that post.
Expert Elite Member
Message 4 of 9
lena.talkhina
Hello @milindnalgirkar  !
Great to see you here on .NET Forum.
Did Alexander's links helped you to find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 5 of 9
milindnalgirkar
I tried almost all options..nothing is working...
Message 6 of 9
Alexander.Rivilis
Please show your code was tried to use and maybe I can help you.
Expert Elite Member
Message 7 of 9
Alexander.Rivilis
Try this code:
using Autodesk.AutoCAD.Runtime;
using Autodesk.Internal.Windows;
// This line is not mandatory, but improves loading performances
[assembly: CommandClass(typeof(CloseCommanLine.MyCommands))]
namespace CloseCommanLine
  public class MyCommands
    [CommandMethod("CC")]
    public void CC()
      EnableCloseCommandLineWindow();
      DisableCloseCommandLineWindow();
    static void EnableCloseCommandLineWindow()
      Autodesk.AutoCAD.Internal.Windows.ProfileManager.LoadHideableDialogSettingsDictionary();
      HideableDialogSettingsDictionary dict =
        Autodesk.Windows.TaskDialog.HideableDialogSettingsDictionary;
      if (!dict.ContainsKey("MainFrame.CommandLineHideWindow"))
        HideableDialogSettings sets = new HideableDialogSettings();
        sets.Application = "";
        sets.Id = "MainFrame.CommandLineHideWindow";
        sets.Title = "Command Line – Close Window";
        sets.Category = "Command Line";
        sets.Result = 6;
        dict.Add(sets);
      try
        dict.SetResult("MainFrame.CommandLineHideWindow", 6);
        Autodesk.AutoCAD.Internal.Windows.ProfileManager.SaveHideableDialogSettingsDictionary();
      catch { }
    static void DisableCloseCommandLineWindow()
      try
        if (dict.ContainsKey("MainFrame.CommandLineHideWindow"))
          dict.Remove("MainFrame.CommandLineHideWindow");
      catch { }
You have to add references to AdWindows.dll and AcWindows.dll
Expert Elite Member
Message 8 of 9
milindnalgirkar
Thank you so much for reply. This solution works perfectly to Autocad 2020 and 2021, but is not working to Autocad  2019.
Any reason to this? Please suggest.
Message 9 of 9
Alexander.Rivilis
I've tested with AutoCAD 2019 (with all updates). This code works as expected:
Expert Elite Member
