Attach Property Set in a Object
seabrahenrique
seabrahenrique
Hello guys.
I'm trying to write a code to Civil 3D that can add a property set to DBObjects in my Document, and until now i have this:
    [CommandMethod("ADDPP")]
    public static void AddPropertySet()
        Database acDBase = Application.DocumentManager.MdiActiveDocument.Database;
        using (var propDic = new DictionaryPropertySetDefinitions(acDBase))
            using (Transaction trans = acDBase.TransactionManager.StartTransaction())
                var propSetDef = new PropertySetDefinition();
                var PropDef = new PropertyDefinition();
                PropDef.Name = "name";
                PropDef.DefaultData = "value";
                propSetDef.Definitions.Add(PropDef);
                propDic.AddNewRecord("test", propSetDef);
                trans.AddNewlyCreatedDBObject(propSetDef, true);
                BlockTable bTb = trans.GetObject(acDBase.BlockTableId, OpenMode.ForWrite) as BlockTable;
                BlockTableRecord bTbR = trans.GetObject(bTb["a"], OpenMode.ForWrite) as BlockTableRecord;
                PropertyDataServices.AddPropertySet(bTbR, propSetDef.ObjectId);
                trans.Commit();
The code add a PropertySetDefinition in my drawing an also add a Property inside that... But the problem is when i try to attach the PPset in my Object, here:
There is no compile error, but when i check my drawing and my named "a" block, i can't see the property set added here:
I don't know where i wrong... Is there something like a "synchronize" to the propertys appears in my block?
Thanks again 🙂
norman.yuan
I am sure you do know that BlockTableRecord is block definition and is not "visible". WHat you see in the MOdelSpace/Layout PaperSpace are BlockReferences. So, you need to attach PropertySet Data to BlockReferences.
Norman Yuan
Drive CAD With Code
seabrahenrique
Pretty obvious... Thanks!
