Assign a selected object to a geometry type
Hello ,
I am new to programming using c# in autocad
I have selected some objects in autocad drawing using ( c# code )  as the part of code followed :
foreach (SelectedObject sobj in ss)
Entity ent = trans.GetObject(sobj.ObjectId, OpenMode.ForWrite) as Entity;
if (ent != null)
//edt.WriteMessage("\n Type of object is : " + ent.GetType().FullName);
if (ent.GetType().Name == "PolyLine")
Polyline pl = new Polyline();
pl = ent;
so when i write ( pl = ent;) it gives me an error that it can't be assigned and have to converted i first.
so how can i do the conversion ?
Thanks ,,
_gile
You can just downcast the Entity into a Polyline:
Polyline pl = (Polyline)ent;
But you could do it more simple and efficient:
Polyline pl = trans.GetObject(sobj.ObjectId, OpenMode.ForWrite) as Polyline;
if (pl != null)
Or, even more efficient, check the ObjectId.ObjectClass before opening it
if (sobj.ObjectId.ObjectClass == RXObject.GetClass(typeof(Poilyline)))
    // here you're sure this is a polyline so you can directly cast
    Polyline pl = (Polyline)trans.GetObject (sobj.ObjectId, OpenMode.ForWrite)
You can also use a SelectionFilter to insure the selection only contains Polylines.
Gilles Chanteau
GileCAD
GitHub
Thanks a lot , it worked
