Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Argument 2: cannot convert from 'void'
dinhthit25
dinhthit25
i stuck at this problem Argument 2: cannot convert from 'void' to 'Autodesk.AutoCAD.Colors.Color'
does anyone know how to fix this or give me an advise how to fix this
im using C#.net framework 4.8
private void ApplyColorsTo3DObject()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    if (_color1 == null || _color2 == null)
        ed.WriteMessage("\nPlease choose two colors.");
        return;
    using (var docLock = doc.LockDocument())
        PromptEntityOptions peo = new PromptEntityOptions("\nSelect a 3D solid:");
        peo.SetRejectMessage("\nOnly 3D solids are allowed.");
        peo.AddAllowedClass(typeof(Solid3d), true);
        var per = ed.GetEntity(peo);
        if (per.Status != PromptStatus.OK)
            ed.WriteMessage("\nNo valid 3D solid selected.");
            return;
        using (Transaction tr = db.TransactionManager.StartTransaction())
            Solid3d solid3d = tr.GetObject(per.ObjectId, OpenMode.ForWrite) as Solid3d;
            if (solid3d == null)
                ed.WriteMessage("\nSelected object is not a valid Solid3d.");
                return;
            try
                // Tạo FullSubentityPath để truy cập BREP
                var fullSubentityPath = new FullSubentityPath(new[] { per.ObjectId }, new SubentityId(SubentityType.Null, IntPtr.Zero));
                using (var brep = new Brep(fullSubentityPath))
                    int faceIndex = 0;
                    foreach (Autodesk.AutoCAD.BoundaryRepresentation.Face face in brep.Faces)
                        try
                            // Lấy SubentityId của mặt
                            var subEntityId = face.SubentityPath.SubentId;
                            // Chọn màu xen kẽ dựa trên chỉ số mặt
                            var colorToApply = (faceIndex % 2 == 0) ? _color1 : _color2;
                            solid3d.SetSubentityColor(subEntityId, ApplyColorToFace(solid3d, face, colorToApply));
                            faceIndex++;
                        catch (System.Exception ex)
                            ed.WriteMessage($"\nError applying color to face: {ex.Message}");
                ed.WriteMessage($"\nError processing solid: {ex.Message}");
            tr.Commit();
private void ApplyColorToFace(Solid3d solid, Autodesk.AutoCAD.BoundaryRepresentation.Face face, Autodesk.AutoCAD.Colors.Color color)
    try
        var subentityId = face.SubentityPath.SubentId;
        solid.SetSubentityColor(subentityId, color);
        Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage($"\nError applying color: {ex.Message}");
ActivistInvestor
Your code is calling SetSubEntityColor() and passing it an argument that is the result of a method that returns void.
dinhthit25
thanks you point it out for me
cuongtk2
I don't understand why you use the ApplyColorToFace function when you could simply add one more parameter for the color in solid3d.SetSubentityColor(subEntityId, colorToApply).
dinhthit25
may i ask do you know how to fix that line
i try changes
ApplyColorToFace
and it wont paint the color anymore
dinhthit25
now you mention it, ApplyColorToFace not necessary
