Arc length Symbol
Arc length Symbol
Arc length Symbol
I have the following code which creates an arc in dimension.
How can I remove the "Arc length Symbol" symbol?
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
namespace cota_linear
    public class Class1
        [CommandMethod("cotaLinear")]
        public void cotas()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            using (Transaction trans = db.TransactionManager.StartTransaction())
                BlockTable table = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
                BlockTableRecord rec = (BlockTableRecord)trans.GetObject(table[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                RotatedDimension dim = new RotatedDimension();
                dim.XLine1Point = new Point3d(0, 15, 0); // StartPoint
                dim.XLine2Point = new Point3d(20, 20, 0); // EndPoint
                dim.DimLinePoint = new Point3d(55, 20, 0); // Altura da cota
                dim.SetDatabaseDefaults();
                dim.DimensionStyle = db.Dimstyle;
                rec.AppendEntity(dim);
                trans.Commit();
Hallex
The same way
 [CommandMethod("arcdimens")]
 public void demo()
 Database db = doc.Database; using (Transaction trans = db.TransactionManager.StartTransaction())
BlockTableRecord rec = (BlockTableRecord)trans.GetObject(table[BlockTableRecord.ModelSpace], OpenMode.ForWrite); ArcDimension arcdim = new ArcDimension(new Point3d(0,0,0),new Point3d(-10,0,0),new Point3d(10,0,0),new Point3d(0,10,0),"",db.Dimstyle);
 rec.AppendEntity(arcdim);
 trans.AddNewlyCreatedDBObject(arcdim, true);
 trans.Commit();
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Hallex
This one is without arclength symbol
        public void demo2()
                ArcDimension arcdim = new ArcDimension(new Point3d(0, 0, 0), new Point3d(-10, 0, 0), new Point3d(10, 0, 0), new Point3d(0, 10, 0), "", db.Dimstyle);
                arcdim.ArcSymbolType = 2;//0- Preceding dimension text; 1 - Above dimension text; 2 - None
                trans.Commit();
Grateful friend.
Problem solved.
Hallex
Glad to hep
Cheers 🙂
~'J'~
