After Running a Sync Function, Right Clicking a layout crashes AutoCAD
Poncho_Slim
Message 1 of 1
Poncho_Slim
I have built a function that backs up data from SheetSet Manager to a database. When this function is ran, it successfully completes, and the user is able to continue working. However, I have an odd error case.
If the user runs this command, and after it completes, they then right click a layout tab, the whole AutoCAD program crashes. This happens every time this case comes up. I have narrowed the crash down to this one function.
I am using AutoCAD 2023 on Windows 10.
Here is the code to the function. This function calls what I beleive is the culprit: The SheetSet(sheetset) constructor (Line 12) . I have come to this conclusion because I used the base constructor I made with no sheetset path and there was no crash induced.
public Routine_SyncSheetSet(Project project)
            try
                if (project == null)
                    return;
                if (project.InDB)
                    SheetSet sheetSet = new SheetSet(project.SheetSet);
                    Dictionary <string, Sheet> SheetSetSheets = new Dictionary<string, Sheet>();
                    if (sheetSet == null)
                        MessageBox.Show($"Error - Detected SheetSet was not found/Error extracting data from sheetset:\n{project.SheetSet}");
                        return;
                    foreach (Sheet sheet in sheetSet.Sheets)
                        if(!SheetSetSheets.ContainsKey($"{sheet.Number} {sheet.RS}"))
                            SheetSetSheets.Add($"{sheet.Number} {sheet.RS}", sheet);
                            if (sheet.Check())
                                Sheet sheetcopy = new Sheet(sheet);
                                sheet.Select();
                                sheetcopy.IssueDate = sheet.IssueDate;
                                sheetcopy.Update(); // Update the Sheets that are in the Database
                            sheet.Insert(); // Add the Sheets that are not in the Database
                    // Query the all the sheets with the SheetSet from the Database
                    Dictionary<string, Sheet> DBSheets = new Dictionary<string, Sheet>();
                    SqlConnection conn = Utils.DBUtils.GetOpenConnection();
                    SqlCommand cmd = new SqlCommand(SheetsQuery(project.SheetSet), conn);
                    SqlDataReader reader = cmd.ExecuteReader();
                    while (reader.Read())
                        // Pull each sheet from the database and add it to the DBSheets dictionary
                        Sheet sheet = new Sheet(reader);
                        if (!DBSheets.ContainsKey($"{sheet.Number} {sheet.RS}"))
                            DBSheets.Add($"{sheet.Number} {sheet.RS}", sheet);
                    reader.Close();
                    // If the sheet is in the Database, but not in the SheetSet, delete it
                    foreach (string fullSheetNumber in DBSheets.Keys)
                        if (!SheetSetSheets.ContainsKey(fullSheetNumber))
                            DBSheets[fullSheetNumber].Delete();
                Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\nSheetset Synced");
            catch (Exception ex)
                new ExceptionTools(ex).HandleException();
Looking at the Sheet Set Constructor, there is code here that I believe is causing the Layout Error.
public SheetSet(string fullpath)
    FullPath = fullpath;
    ObjectName = "SheetSet";
    Sheets = GetSheets(FullPath);
public List<Sheet> GetSheets(string fullpath)
    List<Sheet> Sheets = new List<Sheet>();
    IAcSmSheetSetMgr sheetsetmgr = new AcSmSheetSetMgr();
    AcSmDatabase sheetset = sheetsetmgr.OpenDatabase(fullpath, false);
    ProcessComponents(sheetset.GetSheetSet(), Sheets);
    if (Error)
        MessageBox.Show(ErrorString, "Error Processing SheetSet", MessageBoxButton.OK, MessageBoxImage.Error);
    sheetsetmgr.Close(sheetset);
    return Sheets;
private void ProcessComponents(IAcSmComponent component, List<Sheet> sheets)
    try
         // Attempt to cast the component to AcSmSubset
         AcSmSubset subset = component as AcSmSubset;
         if (subset != null)
              // Recursively process child components of the subset
              IAcSmEnumComponent enumComponent = subset.GetSheetEnumerator();
              while (true)
                  IAcSmComponent childComponent = enumComponent.Next();
                  if (childComponent == null)
                      break;
                  ProcessComponents(childComponent, sheets);
         else
              // Attempt to cast the component to AcSmSheet
              AcSmSheet sheet = component as AcSmSheet;
              if (sheet != null)
                   // Process the sheet
                   IAcSmAcDbObjectReference layout = sheet.GetLayout();
                   string sheetTitle = sheet.GetName();
                   string fullSheetNumber = sheet.GetNumber();
                   if (fullSheetNumber == "" || fullSheetNumber == null)
                       return;
                   string sheetNumber = "";
                   string rsNumber = "";
                   string rstype = "";
                   Utils.Utils.SheetTitleParse(fullSheetNumber, ref sheetNumber, ref rsNumber, ref rstype);
                   string sheetFullPath = layout.GetFileName();
                   string delta = "";
                   string dateTimeString = "";
                   DateTime dateTime = DateTime.Now;
                   string ca = "";
                   string reason = "";
                   try
                       delta = sheet.GetCustomPropertyBag().GetProperty("**DO_NOT_EDIT**1_DELTA").GetValue();
                       dateTimeString = sheet.GetCustomPropertyBag().GetProperty("**DO_NOT_EDIT**3_DATE-IS").GetValue();
                       ca = sheet.GetCustomPropertyBag().GetProperty("**DO_NOT_EDIT**4_RFISUB#").GetValue();
                       reason = sheet.GetCustomPropertyBag().GetProperty("**DO_NOT_EDIT**5_REASON").GetValue();
                      Error = true;
                      ErrorString = "SheetSet -> Process Components -> Format of the Sheets in SheetSet is not correct. Error with pulling **DO_NOT_EDIT** data";
                      return;
                  string RFI = "";
                  string SUB = "";
                  if (delta == "Value")
                      delta = "";
                  if (reason == "Value")
                      reason = "";
                  if (dateTimeString == null || dateTimeString == "Value" || dateTimeString.Trim() == "")
                      dateTime = DateTime.Parse("2000-01-01");
                  else
                      if (DateTime.TryParse(dateTimeString, out DateTime dt))
                          dateTime = dt;
                      else
                  CAtoRFISUB(ca, ref RFI, ref SUB);
                  sheets.Add(new Sheet(FullPath, sheetTitle, sheetNumber, rsNumber, sheetFullPath, delta, dateTime, RFI, SUB, reason));
            // Else, skip the component if it's neither a subset nor a sheet
Here is some information that I am given when the Exception is raised:
Any thoughts, help, or advice would greatly be appreciated.
Thank you!
Replies (0)
