I am using AutoCAD Electrical 2018 and am trying to use the AECOMPONENT Command and insert a component without opening the Icon Menu dialog box using C#. I know of the sendstringtoexecute command, but it seems as though only the "-INSERT" command works with this. The problem with INSERT is that it does not break the wire upon insert.
Is there any way to use AECOMPONENT without any user interaction and have it break the wire when the component is inserted? Or is there a way to use the INSERT command and immediately break the wire using another command afterwards?
