Adjusting appearance of leader drawn with VB.NET
Using some slightly modified code from the samples provided by Autodesk as shown below I'm attempting to draw a simple leader with MText annotation.
In the attached bitmap the top leader shows the result of running the code and the bottom one the appearance I want which is obtained by changing the AutoCAD properties of the leader under
Text
Text pos vert
from 'Above' to 'Centered'
I can't identify anything in the API which allows me to draw with this change, but feel it should be there, so help is needed.
Searching the web for code to draw leaders, basically only returns minor variations on this code with only the same functionality.
Laurie Comerford
   <CommandMethod("TDD")> _
        Public Sub TestDrawLeader()
        DrawLeader("Here it is", New Point3d(0, 0, 0), New Point3d(15, 5, 0))
    End Sub ' AddLeaderAnnotation
    ''' <summary>
    '''  Called from:  AddLeaderAnnotation
    ''' </summary>
    ''' <returns></returns>
    ''' <remarks></remarks>
    Function DrawLeader(ByVal spText As String, ByVal pPtStart As Point3d, ByVal pPtEnd As Point3d) As Boolean
        Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Dim acBlkTbl As BlockTable
        Dim acBlkTblRec As BlockTableRecord
        Try
            ' Start a transaction
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                ' Open the Block table for read
                acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                ' Open the Block table record Model space for write
                acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                ' Create the MText annotation
                Dim acMText As MText = New MText()
                acMText.SetDatabaseDefaults()
                acMText.Contents = spText
                acMText.Location = New Point3d(pPtEnd.X + 7, pPtEnd.Y, 0)
                acMText.Attachment = AttachmentPoint.MiddleLeft
                acMText.Width = 0
                ' Add the new object to Model space and the transaction
                acBlkTblRec.AppendEntity(acMText)
                acTrans.AddNewlyCreatedDBObject(acMText, True)
                ' Create the leader with annotation
                Dim acLdr As Leader = New Leader
                acLdr.SetDatabaseDefaults()
                acLdr.AppendVertex(pPtStart)
                acLdr.AppendVertex(pPtEnd)
                acLdr.AppendVertex(New Point3d(pPtEnd.X + 5, pPtEnd.Y, 0))
                acLdr.HasArrowHead = True
                acBlkTblRec.AppendEntity(acLdr)
                acTrans.AddNewlyCreatedDBObject(acLdr, True)
                ' Attach the annotation after the leader object is added
                acLdr.Annotation = acMText.ObjectId
                acLdr.EvaluateLeader()
                ' Commit the changes and dispose of the transaction
                acTrans.Commit()
            End Using
            Return True
        Catch ex As SystemException
            MsgBox("Unable to  with Function 'DrawLeader' due to:" & vbCrLf & Err.Description)
            Return False
        Finally
        End Try
    End Function ' DrawLeader
Jeff_M
The DIMTAD property controls the position of the Mtext, it is initially set to the CUrrent Dimstyle's value. Override it for the leader to ensure it acts how you want.
                acLdr.Dimtad = 0
Jeff_M, also a frequent Swamper
Hi Jeff,
Thanks.   I'm only left with adding tables and creating the random drawing tools to get back to where the VBA code was 2 years ago.
Shouldn't play so much golf I guess.
Laurie Comerford
quyenpv
I want to use the above DrawLeader function but how can I manually select the coordinates on the drawing without having to enter it as fixed as the code above
