Adding User conrol into Palette with C#
deusextechnic
Message 1 of 9
deusextechnic
I am trying to add a user control to a palette. I used the below method sucessfully with VB.net but it is not working with C#.  the mainPalette.add() method is throwing up : Error 5 The best overloaded method match for 'Autodesk.AutoCAD.Windows.PaletteSet.Add(string, System.Uri)' has some invalid arguments
public static PaletteSet mainPalette = null;
[CommandMethod("POCFind")]
public static void pocfind()
try
if (mainPalette == null)
POCForm mainForm = new POCForm();
mainPalette = new PaletteSet("POC ADD");
mainPalette.Add("TEST", mainForm);
mainPalette.Visible = true;
// populateDatabaseFromCSVAsync();
Thanks in advance.
Replies (8)
Message 2 of 9
Jeff_M
Is the POCForm a UserControl?
Jeff_M, also a frequent Swamper
Message 3 of 9
deusextechnic
Yes. Judging by the error message, it seems to be trying to use it as an Uri. I can't see any reason it would do this. Like I said, I simply translated a snip of VB.net that i succesfully used previously to C#.
Message 4 of 9
_gile
The PaletteSet.Add() method is to be used with UserControl deriving from System.Windows.Forms.UserControl (i.e. Winform UserControl).
If he POCform class derives  from System.Windows.Controls.(i.e. WPF UserControl), you have to use PaletteSet.AddVisual() method.
Gilles Chanteau
GileCAD
GitHub
Message 5 of 9
deusextechnic
That was it. Thanks.
Message 6 of 9
jtibbetts73
Observer
Observer
How can you dynamically remove a user control from the paletteset? I don't see a remove method in the object browser
Message 7 of 9
_gile
@jtibbetts73
You can use the PaletteSet.Remove(int index) method.
Gilles Chanteau
GileCAD
GitHub
Message 8 of 9
jtibbetts73
Observer
Observer
But how do you get the index value of a specific palette if they are reordered whenever one is activated? Is there a way to get the index by name or something? I dont see any methods in the object model.
say you have 4 palettes in the set:
var multiplePaletteSet = new PaletteSet();
var multiplePaletteSet .Palette1 = multiplePaletteSet .AddVisual("Palette1", wpfForm1);
var multiplePaletteSet .Palette2 = multiplePaletteSet .AddVisual("Palette1", wpfForm2);
var multiplePaletteSet .Palette3 = multiplePaletteSet .AddVisual("Palette1", wpfForm3);
var multiplePaletteSet .Palette4 = multiplePaletteSet .AddVisual("Palette1", wpfForm4);
so now user clicks around between the palette tabs, effectively changing the active palette dynamically, but on a specific user action in one of the palettes, I need to remove a different palette from the paletteset. How do I find/select/identify a palette if it is not the active one?
Remove(2);
Message 9 of 9
norman.yuan
Firstly, you really should not directly instantiate a PaletteSet object. Instead, always derive your custom one from PaletteSet class. In the derived class, you can track which Palette is currently the active one, and do the Palette adding/removing.
To tracking which Palette is the currently active one, you handle PaletteSet.PaletteActivated event.
For example, with that event handler, you would have a class member "currentPalatteName". Then, when you remove Palette, you do:
for (int i=0; i<this.Count; i++)
  var name=this[i].Name;
  if (name!=currentPaletteName && name==[PaletteNameToRemove])
    this.RemoveAt(i);
    break;
Norman Yuan
Drive CAD With Code
