Adding trusted locations through the api
rbastiaans
rbastiaans
Hi Guys,
Does anybody know if it's possible to add trusted locations through the api in 2014?
Thanks.
Remco
I think you can add trusted path using "TRUSTEDPATHS" System variable. But for Details you can go through below two links which might be useful for you:
http://adndevblog.typepad.com/autocad/2013/01/autodesk-autoloader-white-paper.html
http://docs.autodesk.com/ACD/2014/ENU/index.html?url=files/GUID-2FB4611D-F141-48D5-9B6E-460EB59351AF...
rbastiaans
Thanks!
I didn't know you could add two paths using the command line, now I can implement it in my .net solution as well.
Just use a semicolon between the two paths.
