Adding an AeccPoint to Drawing
How do I add a new AeccPoint (Civil 3D) to a drawing?
I'm moving over from the COM side and I have hit a road block.
I can create 3d points to add to autocad lines but I have not been able to find any docs on adding stand-alone points to a drawing.
Any help would be great!
augusto.goncalves
Hi Scott,
This is more related to Civil 3D API, so in future I would suggest you use that forum.
Now there is not .NET API to add new AeccPoint on Civil3D drawings...you need to use COM API (from .NET code) with AeccDocument.Points.Add() then you can access from .NET API using its objectID (which returns a .NET PointEntity object)
Augusto Goncalves
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Thanks for the answer!
