Add Property to .Net Project - PnPDatabaseMode
dave.wolfe
Advisor Advisor
dave.wolfe
I'm using the following code to add a property to a table.
var prj = PlantApplication.CurrentProject.ProjectParts["Piping"];
                PnPDatabaseMode prevMode = prj.Mode;
                prj.Mode = PnPDatabaseMode.Exclusive;
                using (PnPDatabase db = PnPDatabase.Open(prj.DataCacheFile))
                    PnPTable enginitems = db.Tables["EngineeringItems"];
                    if (enginitems.Columns.Contains(projectcolum))
                        return;
                    PnPColumn col = new PnPColumn(projectcolum, typeof(string), PnPDatabase.DefaultStringValueLength);
                    enginitems.Columns.Add(col);
                    db.AcceptChanges();
                prj.Mode = prevMode;
However, I get an error in the Datalinksmanager when I try to set the PnPDatabaseMode to Exclusive.  Any ideas?
The PnPDatabaseMode was shared, but the error says it's already opened exclusive.
Dave Wolfe
Isaiah 57:15
Plant 3D Wish list
fenton_webb
The database is already opened in the project so trying to go exclusive on another instance of PnPDatabase will always fail.
Try changing the code to this:
        [CommandMethod("PNPADDCOL", CommandFlags.Modal)]
        public static void PnPAddCol()
// commented out wrong code
            var db = prj.DataLinksManager.GetPnPDatabase();
            //using (PnPDatabase db = PnPDatabase.Open(prj.DataCacheFile))
                if (enginitems.Columns.Contains("TestNewCol"))
                    return;
                PnPColumn col = new PnPColumn("TestNewCol", typeof(string), PnPDatabase.DefaultStringValueLength);
                db.AcceptChanges();
Fenton Webb
AutoCAD Engineering
