Add File1.dwg contents to File2.dwg
soari.do
Message 1 of 17
soari.do
I have two File1.dwg and File2.dwg with some contents in both of them.
I want to add File1 contents to the contents of File2
please help.  My code is
public void file2file(string fromFile, string toFile) {
// define souce DB
Database fromDb = new Database(false, true);
// define object collection
ObjectIdCollection acObjIdColl = new ObjectIdCollection();
// Lock the current document
using (fromDb) {
// open source file
fromDb.ReadDwgFile(fromFile, FileOpenMode.OpenForReadAndAllShare, false, null);
// Start a transaction
using (Transaction acTrans = fromDb.TransactionManager.StartTransaction()) {
// Open the Block table record for read
BlockTable acBlkTbl;
acBlkTbl = acTrans.GetObject(fromDb.BlockTableId,
OpenMode.ForRead) as BlockTable;
// Open the Block table record Model space for write
BlockTableRecord acBlkTblRec;
acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace],
OpenMode.ForRead) as BlockTableRecord;
// copy/paste each object
foreach (ObjectId id in fromBtr) {
Entity ent = (Entity)fromTr.GetObject(id, OpenMode.ForWrite);
acObjIdColl.Add(ent.ObjectId);
// Save the new objects to the database
acTrans.Commit();
// Unlock the document
// Create a new drawing to copy the objects to
Database acDbNewDoc = new Database(false, true);
using (acDbNewDoc) {
// open source file
acDbNewDoc.ReadDwgFile(toFile, FileOpenMode.OpenForReadAndAllShare, false, null);
// Start a transaction in the new database
using (Transaction acTrans = acDbNewDoc.TransactionManager.StartTransaction()) {
// Open the Block table for read
BlockTable acBlkTblNewDoc;
acBlkTblNewDoc = acTrans.GetObject(acDbNewDoc.BlockTableId,
// Open the Block table record Model space for read
BlockTableRecord acBlkTblRecNewDoc;
acBlkTblRecNewDoc = acTrans.GetObject(acBlkTblNewDoc[BlockTableRecord.ModelSpace],
//foreach (Entity id1 in acObjIdColl) {
foreach (Entity nent in acDBObjColl) {
destBtr.AppendEntity(nent);
destTr.AddNewlyCreatedDBObject(nent, true);
// Save the copied objects to the database
acTrans.Commit();
// Set the new document current
acDbNewDoc.SaveAs(toFile, DwgVersion.Current);
Moderator edit: Put code in code window.
Replies (16)
Message 2 of 17
_gile
First, please use the "Insert/Edit code sample" button (</>) when you paste code so that it is more readable.
The code you posted looks like a patchwork of code snippets copied/pasted from multiple sources that seems to never have been tested. It try to use some variable names which have never been declared (fromBtr, formTr, acDbObjCol, destBtr, destTr). Visual Studio alert you for this.
This should work:
        public static void AddFilecontents(string sourceFilename, string targetFileName)
            try
                using (var targetDb = new Database(false, true))
                using (var sourceDb = new Database(false, true))
                    sourceDb.ReadDwgFile(sourceFilename, FileOpenMode.OpenForReadAndAllShare, false, null);
                    targetDb.ReadDwgFile(targetFileName, FileOpenMode.OpenForReadAndAllShare, false, null);
                    var sourceModelSpaceId = SymbolUtilityServices.GetBlockModelSpaceId(sourceDb);
                    var targetModelSpaceId = SymbolUtilityServices.GetBlockModelSpaceId(targetDb);
                    var ids = new ObjectIdCollection();
                    using (var tr = sourceDb.TransactionManager.StartTransaction())
                        var sourceModelSpace = (BlockTableRecord)tr.GetObject(sourceModelSpaceId, OpenMode.ForRead);
                        foreach (ObjectId id in sourceModelSpace)
                            ids.Add(id);
                        tr.Commit();
                    var mapping = new IdMapping();
                    sourceDb.WblockCloneObjects(ids, targetModelSpaceId, mapping, DuplicateRecordCloning.Ignore, false);
                    targetDb.SaveAs(targetFileName, DwgVersion.Current);
            catch (System.Exception ex)
                Application.ShowAlertDialog(ex.Message);
                var ed = Application.DocumentManager.MdiActiveDocument.Editor;
                ed.WriteMessage($"\n{ex.Message}\n{ex.StackTrace}\n");
Gilles Chanteau
GileCAD
GitHub
Message 3 of 17
soari.do
Thank you for the help, it worked.
But the position of the entities are not same as in File1.dwg.
if I use this method in serial for different files, like
AddFilecontents(f1, f2);
AddFilecontents(f3, f2);
f1 contents are overlaped by f3 contents in f2.
Any further suggestion, please...
Message 4 of 17
_gile
Please, post some simple drawing examples to show what you want.
Gilles Chanteau
GileCAD
GitHub
Message 5 of 17
soari.do
Please see the attached image
Message 6 of 17
soari.do
Message 7 of 17
cuongtk2
AddFilecontents(f1, f2) -> f2
public static void AddFilecontents(string sourceFilename, string targetFileName, Point3d insertPoint = new Point3d())
            using (var targetDb = new Database(true, false))
                targetDb.ReadDwgFile(targetFileName, System.IO.FileShare.ReadWrite, false, null);
                using (var sourceDb = new Database(true, false))
                    sourceDb.ReadDwgFile(sourceFilename, System.IO.FileShare.ReadWrite, false, null);
                    Matrix3d matrix = Matrix3d.Displacement(insertPoint - Point3d.Origin);
                    targetDb.Insert(matrix, sourceDb, true);
Message 8 of 17
_gile
@soari.do
The images don't help. The code works with WCS coordinates, keeping the origin (0, 0, 0) of each drawing.
Please provide DWG files so that we can understand the issue.
Here's a screencast showing the following command in action.
        [CommandMethod("TEST")]
        public static void Test()
            AddFilecontents(@"B:\Desktop\Drawings\File1.dwg", @"B:\Desktop\Drawings\File3.dwg");
            AddFilecontents(@"B:\Desktop\Drawings\File2.dwg", @"B:\Desktop\Drawings\File3.dwg");
Gilles Chanteau
GileCAD
GitHub
Message 9 of 17
soari.do
Thank you so much, it helped me a lot, I could adjust the coordinates.
One other issue I faced, which I did not expect.
I coded to remove duplicates, but after removing duplicates, I opened the file and "Select-All" run "Overkill" command, it showed
0 duplicates deleted
8360 overlapping objects or segments deleted. (see image for reference)
I have no idea how to identify and delete overlapping objects.
Please help me to delete overlapping objects using C#.
Message 10 of 17
k005
this is so beautiful! I think there should be something like this;
Adding X or Y coordinates from outside and collecting the drawings according to this coordinate.
There is overlapping in the current code...
I am attaching sample dwg.
In the example, I gave the value of X coordinate 300. and that should go incrementally. In the form of 300, 600,900, so... Of course, in this case, excessive space of drawing-parts may occur. this is editable. from the drawing.
Message 11 of 17
soari.do
Sir,
the code works fine but some asian characters are not displaying correctly in File2, after copying from File1 to File2. In File2 the text displays as ????, but when I click on it and check the properties, it shows correctly in properties.
Could you kindly suggest how to fix it.
Rao
Message 12 of 17
soari.do
Sir,
the code works fine but some asian characters are not displaying correctly in File2, after copying from File1. In File2 the text displays as ????, but when I click on it and check the properties, it shows correctly in properties, but not in model space.
Rao
Message 13 of 17
_gile
Sorry, I have no idea. I only use Latin characters.
Gilles Chanteau
GileCAD
GitHub
Message 14 of 17
cuongtk2
Example:
before:
dwg1: Text style "Standard"  use font txt.shx
dwg2: Text style "Standard"  use font Arial.ttf , dbtext1 content "việt nam"
after import dwg2 to dwg1 :
dbtext1 display content "vi?t nam"  in dwg1, because txt.shx not support Unicode chacrater.
You must note that the font in the textstyle of 2 drawings must be the same.
Message 15 of 17
soari.do
Thank you sir,
Here is the result, please see attached image.
In properties of both files it shows correctly and property name is also same.
But in model space font is not correctly displaying.
Any further settings suggested.
Please.
Thankyou
Rao
Message 16 of 17
_gile
Check the Font of the 'Standard' textstyle in both files.
Gilles Chanteau
GileCAD
GitHub
Message 17 of 17
soari.do
Thank you sir,
I solved in other way.
