AcCoreConsole Will Publish Only the Model Layout
larry.daubenspeck
Message 1 of 1
larry.daubenspeck
I have an AutoCAD addin which draws a simplistic view of my company’s product (given a few variable inputs).  When finished, it saves as both .dwg and .pdf, then emails the two as attachments back to the sales person who made the request.  It works great, producing a scale drawing that the sales people include with their quotations.
Now, I am re-writing this to work with the AcCoreConsole.  All was going well, until I got to the pdf creation.  After reading post after post on this subject, I cobbled together a function which does the job – sort of – and returns True if successful.  The program then creates an email attachment out of the pdf file.  The problem is, the only layout that seems to work is the Model tab.  If I pass in the name of the tab I really want (“Elevation” in my case), the function still returns True, but the main program which called the function just quits when it gets to the line of code that tries to create the attachment.  I put it in a Try-Catch statement, and it doesn’t even make it to the Catch phrase; it just quits, with no indication of an error whatsoever.  I know the Elevation tab exists, because it’s there in the dwg file.  If I change “Elevation” to “Model” it works fine (except there is no border and title block).  Any ideas?
Here is my code:
   Friend Function SaveAsPDF(ByRef PdfDatabase As Database, FilePath As String, FileName As String, LayoutName As String, ByRef ErrorMsg As String) As Boolean
        Try
            'Put the plot in foreground.
            Dim bgPlot As Short = Core.Application.GetSystemVariable("BACKGROUNDPLOT")
            Core.Application.SetSystemVariable("BACKGROUNDPLOT", 0)
            'Get the layout ObjectId List.
            Dim layoutIds As System.Collections.Generic.List(Of ObjectId) = GetLayoutIds(PdfDatabase)
            Using Trans As Transaction = PdfDatabase.TransactionManager.StartTransaction
                Dim collection As DsdEntryCollection = New DsdEntryCollection
                For Each layoutId As ObjectId In layoutIds
                    Dim layout As Layout = Trans.GetObject(layoutId, OpenMode.ForRead)
                    If layout.LayoutName.Contains(LayoutName) Then
                        Dim entry As DsdEntry = New DsdEntry
                        With entry
                            .DwgName = FilePath & FileName & ".dwg"
                            .Layout = layout.LayoutName
                            .Title = FileName
                            .NpsSourceDwg = entry.DwgName
                            .Nps = "Setup1"
                        End With
                        collection.Add(entry)
                Next
                Dim dsdData As DsdData = New DsdData
                With dsdData
                    .SheetType = SheetType.SinglePdf
                    .ProjectPath = FilePath
                    .DestinationName = FilePath & FileName & ".pdf"
                End With
                If System.IO.File.Exists(dsdData.DestinationName) Then System.IO.File.Delete(dsdData.DestinationName)
                dsdData.SetDsdEntryCollection(collection)
                Dim dsdFile As String = dsdData.ProjectPath & FileName & ".dsd"
                'Workaround to avoid promp for dwf file name.
                'Set PromptForDwfName=FALSE in dsdData using StreamReader/StreamWriter
                dsdData.WriteDsd(dsdFile)
                Dim sr As StreamReader = New StreamReader(dsdFile)
                Dim str As String = sr.ReadToEnd
                sr.Close()
                str = str.Replace("PromptForDwfName=TRUE", "PromptForDwfName=FALSE")
                Dim sw As StreamWriter = New StreamWriter(dsdFile)
                sw.Write(str)
                sw.Close()
                dsdData.ReadDsd(dsdFile)
                System.IO.File.Delete(dsdFile)
                Dim plotConfig As PlotConfig = PlotConfigManager.SetCurrentConfig("DWG To PDF.pc3")
                Dim publisher As Autodesk.AutoCAD.Publishing.Publisher = Autodesk.AutoCAD.ApplicationServices.Core.Application.Publisher
                publisher.PublishExecute(dsdData, plotConfig)
                Trans.Commit()
            End Using
            'Reset the background plot value.
            Core.Application.SetSystemVariable("BACKGROUNDPLOT", bgPlot)
        Catch ex As Exception
            ErrorMsg = "Error @ AcadDrawing.SaveAsPDF()." & vbCrLf & ex.Message
            Return False
        End Try
        Return True
    End Function
Larry Daubenspeck
Software Programmer
Draper, Inc.
Replies (0)
