Accoreconsole failing to load dll
BKSpurgeon
BKSpurgeon
Hi folks
I've created a "hello world" dll.
It basically loops through some entities in the model space and prints out the hangle or object id to the editor.
I am trying to netload this dll to accoreconsole. netloading is failing.
I have removed the reference to the troublesome acmgd which would prevent it from working in accoreconsole. But it still refuses to load.
attached is my project.
Any assistance would be much appreciated.
regards
BK
jeff
I have not looked at it but is the location of dll included in "Trusted Paths"?
You can also find your answers @ TheSwamp
BKSpurgeon
THank you Mr Jeff
I will try this out.
For those researching this in the future, if you want to add a trusted path folder location, here it is:
http://www.ccadinc.com/autocad-tutorials-trusted-locations.html
with kind regards
BK
BKSpurgeon
yup works like a charm now.
cheers.
rgds
BK
BKSpurgeon
There is great rejoicing in the land!
Managed to get accoreConsole working with Scriptpro 2.0 to allow for the batch processing of files. This allows for speedy batch processing of many, many autocad files.
Below are my script files: (because this forum will not allow me to upload it):
;Loading the .Net module
Netload "C:\Users\Koshy\Documents\Visual Studio 2013\Projects\BatchProcessingII\countEntities\countEntities\bin\Debug\countEntities.dll"
; Run the command
(command "Count")
(command "save")
Please note that there are to carriage returns at the end of the file.
If you want to avoid using ScriptPro 2.0 and simply want a windows bat file here it is below:
cd D:\Program Files\Actual Autocad Program\AutoCAD 2016
d:
cls
accoreconsole.exe /i "C:\Users\Koshy\Documents\Visual Studio 2013\Projects\BatchProcessingII\Lights.dwg" /s "C:\Users\Koshy\Documents\Visual Studio 2013\Projects\BatchProcessingII\RunCustomNETCmd.scr" /l en-US
PAUSE
I copied that from Augusto Gonglaves or Balaji Ram. or some other such autodesk genious.
any problems please don't hestitate to PM me - if you reply to the thread it's highly likely that i'll miss it.
regards
BK
jayandseth
Community Visitor
Community Visitor
