Access .NET from the COM application object?
Message 1 of 10
Does anyone know if it is possible to access .NET from the COM application object?
I have a stand alone application that accesses the Autodesk.AutoCAD.Interop.AcadApplication object and uses it for various functions.
What I would like to do is to access objects in the .NET namespaces Autodesk.AutoCAD.Runtime,  Autodesk.AutoCAD,Applicationservices,  Autodesk.AutoCAD.Editorinput etc. via the COM-application object.
Is that possible?
Regards
Jan Grenov
Replies (9)
Message 2 of 10
augusto.goncalves
Hi Jan,
No you cannot. The namespaces available under AcMgd and AcDbMgd are for in-process only, meaning just for plug-ins (not external applications).
The alternative is expose what you need to an outside caller using the approach suggested here:
http://through-the-interface.typepad.com/through_the_interface/2009/05/interfacing-an-external-com-a...
Hope this explains.
Augusto Goncalve
Autodesk Developer Network
Augusto Goncalves
Twitter @augustomaia
Message 3 of 10
Hi Augusto
OK. Thanks a lot for your answer. I'll study the alternative that you proposed.
Message 4 of 10
I know you have an answer.
I looked at the answer, but it was beyond me.
Perhaps I can give you another solution, which I think is easier to understand and depends on some very basic code.
Insert a timer in your external application, the sole function of which is to poll for the existance of a file.
Decide what data you wish to have in this file.
Read the file and then delete it.
In your Inprocess class, write data to this file.
Experiment with the timing of your timer.
I have found it can be very quick.
Message 5 of 10
Not a bad idea.
Thanks for sharing it 🙂
Message 6 of 10
Hallex
I have not tried to use Timer
Can you share a simple code with
TIA
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 7 of 10
Well this is not really a timer, but it works fine for me:
Dim cnt As Short = 0
Dim AcadIsReady As Boolean
While Not AcadIsReady
   Try
      If cnt > 10 Then' After ten attempts ...
              MsgBox("Send some error message")
              Exit Sub
      Else
         Try to execute your in-process-function here ' This will fail as long as AutoCAD is busy
         AcadIsReady = True
   Catch ex As Exception
      cnt = cnt + 1
          System.Threading.Thread.Sleep(1000) ' Sleep for one second
   End Try
End While
Message 8 of 10
Hallex
Thanks a lot
Oleg
Message 9 of 10
I am assuming that you have an exe that needs to read events raised in an inprocess dll (referencing acdbmg)
So instead of raing an event which Im not sure how you might do it, write to a file with a message.
In your app, the timer event simply waits for the File.Exists(yourfilename) to return True. The read it and from its message work out what the event was intended to be.
Message 10 of 10
Hallex
Thanks for exoalnation
It's clearly enough,
Regards 🙂
~'J'~
