Access Drawing database without Opening it then Create Objects Inside then Save
john-malulan
john-malulan
Good day Everyone. I'm new to AutoCAD C# Programming asking for your kind assistance.
What I'm trying to do is
1. Access Drawing Database without Opening it in the Editor ( Template Drawing )
2. Create Objects Inside It
3. Assign Layer Property to the Created Objects
4. Save as New Drawing  ( Output Drawing )
I followed this Solution and It works, I can already Access the drawing database and Create Objects Inside it and then save into a different drawing.
https://forums.autodesk.com/t5/net/how-to-open-an-autocad-file-update-and-close-with-save-using-c/td...
But when I try to assign a layer property in the new object I get eKeyNotFound Error even though the Template drawing that I access has that layer.
I also followed this Link but still no Luck.
https://forums.autodesk.com/t5/net/how-change-layer-of-specific-entity/td-p/8577610
Here is my Source Code.
[CommandMethod("CHANGENEW")]
public static void CreateText()
    //Get the template plant database
    Database acCurDb = new Database(false, true);
    string dwgFlpath = @"D:\Users\johnrey.d.malulan\Downloads\Hotaka_New_Type_Test.dwg";
    //Set the output Drawing Directory
    Document acDoc = Application.DocumentManager.MdiActiveDocument;
    string strDWGName = acDoc.Name;
    strDWGName = @"D:\Users\johnrey.d.malulan\Downloads\Output.dwg";
    acCurDb.ReadDwgFile(dwgFlpath, FileOpenMode.OpenForReadAndAllShare, false, null);
    // Start a transaction
    using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
        // Open the Block table for read
        BlockTable acBlkTbl;
        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId,
                                           OpenMode.ForRead) as BlockTable;
        // Open the Block table record Model space for write
        BlockTableRecord acBlkTblRec;
        acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace],
                                              OpenMode.ForWrite) as BlockTableRecord;
        var layerName = "Character";
        // check if the layer already exists
        var lt = (LayerTable)acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForRead);
        if (!lt.Has(layerName))
            // if not create it
            var layer = new LayerTableRecord()
                Name = layerName,
                Color = Color.FromRgb(200, 30, 80)
            lt.UpgradeOpen();
            lt.Add(layer);
            acTrans.AddNewlyCreatedDBObject(layer, true);
            Application.ShowAlertDialog("Layer Created");
        // Create a single-line text object
        DBText acText = new DBText();
        //acText.SetDatabaseDefaults();
        acText.Position = new Point3d(2, 2, 0);
        acText.Layer = layerName;
        acText.Height = 500;
        acText.TextString = "Hello, World.";
        acBlkTblRec.AppendEntity(acText);
        acTrans.AddNewlyCreatedDBObject(acText, true);
        // Save the changes and dispose of the transaction
        acTrans.Commit();
    acCurDb.SaveAs(strDWGName, DwgVersion.Current);
Please help me 😞
_gile
You should use the LayerId property instead.
        public static void CreateFileWithText(string templatePath, string outputDwgPath)
            // create a new Database (within a using statement to ensure the Database to be disposed)
            using (var db = new Database(false, true))
                // read the template dwg file
                db.ReadDwgFile(templatePath, FileOpenMode.OpenForReadAndAllShare, false, null);
                // start a transaction
                using (var tr = db.TransactionManager.StartTransaction())
                    // check if a layer named "Character" already exists and create it if not
                    string layerName = "Character";
                    ObjectId layerId;
                    var layerTable = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead);
                    if (layerTable.Has(layerName))
                        layerId = layerTable[layerName];
                    else
                        tr.GetObject(db.LayerTableId, OpenMode.ForWrite);
                            Name = layerName,
                        layerId = layerTable.Add(layer);
                        tr.AddNewlyCreatedDBObject(layer, true);
                    // get the Model space
                    var modelSpace = (BlockTableRecord)tr.GetObject(
                        SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForWrite);
                    // create a text
                    var text = new DBText
                        Position = new Point3d(2.0, 2.0, 0.0),
                        LayerId = layerId,
                        Height = 500.0,
                    modelSpace.AppendEntity(text);
                    tr.AddNewlyCreatedDBObject(text, true);
                    // save changes to the database
                    tr.Commit();
                // save the new drawing
                db.SaveAs(outputDwgPath, DwgVersion.Current);
Gilles Chanteau
GileCAD
GitHub
Alexander.Rivilis
Change:
with:
acText.LayerId = layerId; // ObjectId of your layer
P.S.: Oops! I did not see the @_gile answer.
Facebook | Twitter | LinkedIn
Expert Elite Member
john-malulan
You're a life saver Sir, Thank you so much. Have a nice day!
