AcadApplication
AcadApplication
AcadApplication
je cherche un code en c # qui permet de tester si autocad est ouvert pour ne pas le relancer et récupérer le model space.
la commande " AcadApplication app = new AcadApplication()" permet de lancer autocad mais je veux éliminer cette étape et utiliser mon model space.
voici le code que je veux le modifier
using System;
using Autodesk.AutoCAD.Runtime;
using System.Collections.Generic;
using System.Windows.Forms;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
using Autodesk.AutoCAD.Colors;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
//using App = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof(ClassLibrary.civiClass))]
namespace ClassLibrary
/// Summary description for civiClass.
public class civiClass
[CommandMethod("line")]
public void line() // This method can have any name
AcadApplication app = new AcadApplication();
AcadDocument doc1 = app.ActiveDocument;
//This example adds a line in model space
AcadLine lineObj;
double[] startPoint = new double[3];
double[] endPoint = new double[3];
//Define the start and end points for the line
startPoint[0] = 1; startPoint[1] = 1; startPoint[2] = 0;
endPoint[0] = 50; endPoint[1] = 200; endPoint[2] = 0;
//Create the line in model space
lineObj = doc1.ModelSpace.AddLine(startPoint, endPoint);
app.Application.Visible = true;
doc1.Regen(AcRegenType.acAllViewports);
app.ZoomAll();
merci
i answer in english:
if i understand you want to start your macro from your already open autocad session.
first you must create a dll project, not executable, then compile and in autocad use the netload command and select the compiled dll. Then you can start your marco
I have the same problem.
I'm making a stand alone .net programm by using the Autodesk.AutoCAD.Interop
This wil allways start a new acad session.
mAcadApp = New AcadApplication
How can I become an object of the existing acad session in an external programm?
Kind regards
System.Runtime.InteropServices.Marshal.GetActiveObject()
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:[email protected]...
Hi, I have the same problem. I'm making a stand alone .net programm by using the Autodesk.AutoCAD.Interop This wil allways start a new acad session. mAcadApp = New AcadApplication How can I become an object of the existing acad session in an external programm? Kind regards
Vous pouvez ajouter:
{color:#0000ff}using{color} System.Runtime.InteropServices;
et
Autodesk.AutoCAD.Interop.AcadApplication app = (AcadApplication)Marshal.GetActiveObject("AutoCAD.Application.17");
