A error “System.AccessViolationException” occur in Acdbmgd.dll
bairuize
Message 1 of 10
bairuize
I use this code but meet A error .“System.AccessViolationException” occur in Acdbmgd.dll
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Interop
Public Class Class1
<CommandMethod("exsat")>
Public Shared Sub testSolidsSelect()
Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim ed As Editor = doc.Editor
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim tr As Transaction = db.TransactionManager.StartTransaction()
Dim sImage_Type = "SAT"
Dim satFullName As String = "D:\123.sat"
Dim curtab As String = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("ctab").ToString()
Dim values(3) As TypedValue
values(0) = New TypedValue(DxfCode.Operator, "<and")
values(1) = New TypedValue(DxfCode.Start, "region")
values(2) = New TypedValue(DxfCode.LayoutName, curtab)
values(3) = New TypedValue(DxfCode.Operator, "and>")
Dim selFilter As New SelectionFilter(values)
Dim prompSelRes As PromptSelectionResult = ed.SelectAll(selFilter)
If prompSelRes.Status <> PromptStatus.OK Then Return
Dim oSset As SelectionSet = prompSelRes.Value
ed.WriteMessage(vbLf + "{0}", oSset.Count)
ed.SetImpliedSelection(oSset)
Dim AcApp As Autodesk.AutoCAD.Interop.AcadApplication = DirectCast(Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication, Autodesk.AutoCAD.Interop.AcadApplication)
Dim ThisDrawing As Autodesk.AutoCAD.Interop.AcadDocument = AcApp.ActiveDocument
Dim pickSset As AcadSelectionSet = ThisDrawing.ActiveSelectionSet
ThisDrawing.Export(satFullName, sImage_Type, pickSset)
pickSset.Clear()
pickSset = Nothing
ThisDrawing = Nothing
AcApp = Nothing
ed.Regen()
End Sub
End Class
Replies (9)
Message 2 of 10
bairuize
could somebody help me. best wishes to you
Message 3 of 10
ActivistInvestor
Did you try stepping through the code to see exactly what line is triggering the exception?  Without knowing more one thing you might try is to use the previous selection set rather than the active selection set.
Message 4 of 10
bairuize
Thanks for your help!
I changed the previous selection set, it has no influence.
Now my code is generating .SAT normally. But when it run to "end sub", VS will report errors "System.AccessViolationException".
Message 5 of 10
ActivistInvestor
Please post your code using the insert code button on the toolbar because your code is too difficult to read when it is not formatted.
It looks like you are starting a transaction and not committing, aborting or disposing it and that is most likely the problem. From what I can tell there isn't any need for a transaction to do what you need.
Message 6 of 10
cuongtk2
"d:/filepath.dat" , or "\\"
Message 7 of 10
bairuize
Public Class Class1
        Dim satFullName As String = "D:/123.sat"
        Try
            ''Dim curlay As String = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("clayer").ToString()
            '  Console.WriteLine(oSset.Count.ToString() + "    " + "b")
            Dim pickSset As AcadSelectionSet = ThisDrawing.PickfirstSelectionSet
            pickSset.Clear()
            pickSset = Nothing
            AcApp = Nothing
            ' ed.Regen()
        Catch ex As Autodesk.AutoCAD.Runtime.Exception
            Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.ToString & vbLf & ex.Message)
        Finally
            Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Find file " & satFullName & " to see result")
        End Try
    End Sub
End Class
Message 8 of 10
bairuize
I post my new code,and I corrected the code as you suggested.But there still occur the error "System.AccessViolationException "
Message 9 of 10
bairuize
I have posted the code according to your suggestion
Message 10 of 10
ActivistInvestor
Remove the above line from your code.
