Im using Navisworks Manage 2018. I am unable to make any changes to the setting of the lights. I can place the lights, but when i go to change any settings it doesnt work. What am I missing here? I have used these lights in the past on an earlier version but they aren't working now.
I can open the dialog boxes, make a change, hit ok and none of the settings show up. Any help will be greatly appreciated.
Solved by ben.jones. Go to Solution.
Hi Ben,
Thank you for taking your time to post this on the forum,
Are you by any chance able to share the file? I would want to take a look at it to give you a more precise answer.
Best Regards,
I figured this one out. I tried several files including ones that i have been able to edit the lights in the past. I finally called autodesk support. Its an issue with 2018 navisworks. He said go back to 2017 and it should work. Apparently its a known issue with 2018. I am now happily editing in 2017.
