Tree structure of Revit .nwc export is different for two similar elements
b.wildekamp
b.wildekamp
Attached a .rvt project and the .nwc export.
Two elements of same family and same type show a different model structure in the selection tree in Navisworks.
This also means that for both elements parameter values are stored on another level.
Does anyone know what might be the cause of this bug?
Thanks in advance!
Bram
hmunsell
Not sure what is causing it, but id be interested to know why this symbols is different. What does that symbol mean?
interesting though... if i copy of of those twice to the left and then re-append the Revit file they all fall into place.
when I delete the original 2, the 2 copies seem to work to.
Howard Munsell
b.wildekamp
Didn't noticed the different symbol yet!
Found this online. Doesn't give me much explanation. Elements aren't in a group or something alike..
Navisworks symbols
Indeed. Replacing the elements solves the issue. For now that is going to be our solution.
Still currious what's causing it..
