I am trying the function "Auto Attaching using Rules" for gatehouse example, I tried several time a lot of combinations to match Task name from GANTT with task name from model but I did not succeed. Can you help me please?
Solved by ronald.loggen. Go to Solution.
@ronald.loggen thanks for answering. Could you explain more in detail what do you mean please? Because the issue is the matching.
Thanks @ronald.loggen for answering, Sets seems are not taken, as you can see in the picture attached. It is the gatehouse sample in Navisworks, it should work just because it is an example!
there is anything in search sets neither. In attach find the gatehouse example, but I guess you should have as well. My questions is how can I "auto attach using rules" matching tasks from timeliner (importing it thorough Microsoft Primavera) and tasks from "selection tree"
Thanks for helping.
Maybe I did not explain well. @ronald.loggen I have to match with tasks from Microsoft Project.
Here is the link for dowloading the Microsoft Project file https://drive.google.com/open?id=1wFbxBart0wEwf-OVqYO0UZO5TJLnal22
Thanks for your support
