Source file for NWD model
tmccar
Advisor Advisor
tmccar
Is there a way to check what source file was used to create a Navisworks NWD file?
patrick.davis
If you select the NWD file on the selection tree, it will tell you the name of the source file. If your NWD has multiple files (DWG, NWC, RVT) then you would want to look at those files individually.
tmccar
Thank you
