Solids of Inventor FDU Assets set to Invisible are being showed in Navisworks.
Solids in Inventor FDU Assets set to Invisible are being showed in Navisworks. What can I do to have  this solids in the Inventor FDU Assets in Navisworks Manage 2019 invisible?
Picture from NavisworksPicture from NavisworksPicture from InventorPicture from Inventor
brettgatti
I am not familiar with the way that Inventor exports to NWC format (from Revit and AutoCAD, it is What You See Is What You Get) or what type of identifiable/searchable data is there, but could you create a Search Set within Navisworks to select and then hide the items that are appearing (if there is an identifiable parameter of some sort that can be used in a search)?
Thanks for your reply bretgatti.
In previous versions of Navisworks(2016) we did not have this issue. There must be a setting to filter during the export from Inventor to Navisworks Manage 2019 to get in Navisworks what you see in Inventor.
It is not workable when you have to change this every time in the Navisworks file.
I did have a look at your proposal and did try to find the solids in the asset models, but unfortunately these are not showed! So I cannot control those with the search set/find items functionality.
Thanks.
