Selection Tree - Set Standard by Category
Kimtaurus
Advisor Advisor
Kimtaurus
In my Navisworks Selection Tree, Standard shows the elements by level and then by category.
I've seen images and videos online where the Standard Selection Tree is sorted by category first. But I haven't found anywhere how to do this in my Navisworks.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
novesvalentin
Hi @Kimtaurus,
I think you need to uncheck the option "divide into levels" inside the Navisworks setting when you are about to export in revit
You can see in the image below when you check the option and when you don't
If this helped solve your problem please mark it as solution, so other users can get this solutions as well.
Valentin Noves
BIM Manager
www.valentinnoves.com
