Selecting related and hiding the rest.
In Navisworks Freedom I open the model. I locate the start of pipe that I need to follow. I would like to highlight the start of the pipe and have Navisworks highlight everything related to that pipe and then I can hide everything else.
Example I am following a flare header, I find and highlight a section, How do I highlight the rest of the header or do I have to follow and highlight each section? Then hide all that is not related to that pipe
Thank,
Drew
dgorsman
If everything in that line has common properties, then you can use the Properties display of the Selection Tree to select by that property and then hide unselected.  Otherwise your options for Navisworks are extremely limited as it doesn't support customization.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
