Select only 1 object that have more objects equal
I have, for exemple, 30 colunms on my model that are equal. Using Find Items, I want to select only 10. Is it possible?
dgorsman
Only if they have some property that can be filtered with the search criteria.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
sureshchotrani
Wellcome to the community:)
Does all columns have same properties? If yes then you can filter 10 columns from 30 same cloumns.
If the 10 coulmns you want to select have different properties/property then you can filter.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
