Announcements
select curtain wall ifc exported from revit
MarceldeGroot
Message 1 of 14
MarceldeGroot
I have a question:
I exported a revit file, with several curtain walls modeled in it, to ifc, for quantity takeoff and clash detection.
As several properties are attached to the curtain wall, it is neccesary to select them, but i can’t find an option te select those curtain walls as a whole, only seperate mullions, doors, windows and panels.
Or is this not possible? (as it is possible in Solibri)
Any tips?
Replies (13)
Message 2 of 14
Alan.johnson1970
Have you tried changing your Selection Resolution
under the  Select & Search dropdown?
Then setting to one of the other resolutions.
You also have the Select same options
You could also set up a search set to find your curtain walls and create a selection set from that.
AJ.
Message 3 of 14
MarceldeGroot
Thanks for the reply.
I tried those options.
Yes, I can select all of the objects from the specific curtain wall and then create a selection set, but that curtain wall itself (including the mullions / panels etc.) not by one click, to show its properties.
The curtain wall itself as a whole also has properties (see attached view from Solibri)
Message 4 of 14
andrea.kikuchi
Autodesk Support
Autodesk Support
Hi @MarceldeGroot
Are you able to share the model with us so we can take a look? I can give you an upload link privately if so, thanks!
Andrea K
Technical Support Specialist
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Message 5 of 14
andrea.kikuchi
Autodesk Support
Autodesk Support
Thanks for the uploads @MarceldeGroot. What properties are you missing exactly? Which method was used to export from Revit? (File>Export) or addins?
Andrea K
Message 6 of 14
MarceldeGroot
Hi Andrea,
I would like to select the curtain wall in Navisworks with just one click, with the properties ‘kozijnmerk’ as the parameter from this curtain wall. (in this case an instance parameter in Revit, see screenshot). I can select the curtain wall directly in Solibri to show its properties, but in Navisworks i can’t find this option to select the curtain wall, to show its own specific parameters, instead of the mullions, panels, etc. separately.
The IFC export was made with the exporter Version 19.1.0, 6/29/2018
2019-03-21 08_59_17-Microsoft Edge.png2019-03-21 09_01_07-Solibri Model Viewer - test Fabwindow export.png
Message 7 of 14
andrea.kikuchi
Autodesk Support
Autodesk Support
Thanks! I can see this parameter when opening the NWC file, do you have this same tab?
Andrea K
Message 8 of 14
MarceldeGroot
no, unfortunately,
when i open the IFC (or the NWC cache file), i see this:
(in Navisworks Simulate, but i don't think that makes a difference)2019-03-21 14_00_30-test Fabwindow export.ifc - Autodesk Navisworks Simulate 2019.png
Message 9 of 14
andrea.kikuchi
Autodesk Support
Autodesk Support
Can you tell me if your Navisworks is up to date?
Andrea K
Message 10 of 14
MarceldeGroot
I think so, yes, there was 1 update, but after install, it makes no difference:
Message 11 of 14
andrea.kikuchi
Autodesk Support
Autodesk Support
Hi @MarceldeGroot ,
I have brought this issue to the development team, but at this moment it looks like the file can be viewed with the expected behavior in Navisworks 2018.
Andrea K
Message 12 of 14
Tomislav.Golubovic
Why do an Export, why not just read the native file?
Message 13 of 14
MarceldeGroot
Okay, thanks.
So this means there’s no issue with the file in Navisworks 2018, but only in the 2019 manage or simulate version?
Message 14 of 14
is there any update  regarding this issue am facing the same problem plzz
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
