Sample csv file to support Timeliner
JKRevit
JKRevit
My company does not use Microsoft Project for projects under a certain size. I'm trying to find a sample .csv to review what the .csv formatting must be to share data in the Navisworks Timeliner tool. My question is based on the assumption that there is no file created in MS Project nor in Primavera. All data is built directly in the .csv file, and then imported into Navisworks. Is this possible? If so, does someone have a sample .csv file they could share that would illustrate how information is formatted in the .csv file? Thanks very much!
a_meteni
You might try NW sample data source files. the files are located in the program folder, i.e.: ..\Program Files\Autodesk\Navisworks Manage 2019\Samples.
JKRevit
Thanks for replying to my post. I looked in the location that you suggested, but the only .xls file I found was a three column list with miscellaneous product information. I did not find any sample data source files. I will have to dig deeper into the Navisworks section of the Autodesk Knowledge Center. If I find anything, I'll try to link it in this thread.
a_meteni
Searching my OLD folder, I found the attached file!
Hope you find what you looking for. and please keep us posted with any updates.
JKRevit
Thank you so much! This is what I was looking for. Since my last post, I found a good YouTube video regarding the Timeliner tool
https://www.youtube.com/watch?v=pOr06v4VNOs
I appreciate your effort.
