revit volume
revit volume
Message 1 of 13
revit volume
When I insert a Revit file inside of Navisworks through the RVT file itself, it inserts correctly and in the correct coordinates, but it is not displaying the "Volume" property. My revit model is a Generic Model.
Replies (12)
Message 2 of 13
dlindsey_bim
Depending on what your Selection Resolution is set to, you won't see all the properties of the object.  Try changing your Selection Resolution to "First Object" and see if that helps see the appropriate properties.
Or, don't change the Selection Resolution, just select the object, go to the Selection Tree and choose the different "levels" of geometry until you see the properties you are looking for.
See the attached image...if I select anything else other than what I have selected in the Selection Tree, I won't see the proper Properties, thus not seeing the Volume.
Message 3 of 13
@dlindsey_bim  Unfortunately in my not appear the elements tab.
Message 4 of 13
dlindsey_bim
How are you getting the file into Navisworks from Revit, exporting NWC from Revit or opening the Revit file directly in Navisworks?
Message 5 of 13
Opening the Revit file (merge) directly from NavisWorks.
Message 6 of 13
dlindsey_bim
Okay, go to your Options in Navisworks, then go to File Readers.  Click on Revit, then makes sure the "Convert element properties" is checked.  I believe this is turned off by default.
Message 7 of 13
The "Convert element properties" option is selected.
Message 8 of 13
dlindsey_bim
Okay, what about the top option "Convert element parameters", what is that set to?
If you haven't tried this yet either, especially if you change any settings, delete the NWC that's been created after you opened the Revit file in Navisworks.  Open a new Navisworks file and bring the Revit file in again.
Message 9 of 13
I created a new project and I continue without the volume information
in revit
Message 10 of 13
dlindsey_bim
Any chance you can share the Revit file for me to look at/test?
Also, do you get the same results if you export a NWC from Revit and open the NWC in Navisworks?
Message 11 of 13
After several attempts copy as @dlindsey_bim settings that helped me by sending his settings
Message 12 of 13
How did you solve it?
Message 13 of 13
ce20m102
Community Visitor
Community Visitor
hi can u exlain how u solved the issue finally
