Revit family to Naviswork animation
pe_simon
pe_simon
Hi, I want the family export to .NWC to do animation about the mounting combination.
But the family exported to naviswork, when I select it, it not separate to what I want it. It selected one set or few set.
How can I make it what I want? Thanks.
pe_simon_0-1721295620370.png How to break it to two part?
alan.johnson7YLND
If you select one of the elements do you get the move gizmo?
If you do then you should be able to move that element or elements
So If you can do this then you should be able to animate.
