Revit automatically transforms my NWCs
Chris-VC_Studio
Chris-VC_Studio
Help, somehow Revit is automatically lowering my model.
I know this has to be an easy fix, but every time I export an NWC out of Revit and append it to our coordination model, it comes already transformed -1 13/16" lower than everyone else when it should be zero. This has just started happening this week. I have checked my project base point and survey point, and both are at zero elevation.
Any ideas or suggestions would be helpful!!!!
hmunsell
what are you export settings set to?
  • Project Internal
  • Shared
Howard Munsell
Chris-VC_Studio
We are using shared coordinates and have been for the last 6 months or so; just suddenly, every NWC export I do comes out 1 13/16" lower than it was a month ago.
hmunsell
hmmmm if your using Shared Coordinates then, in theory, the PBP and SP shouldn't matter. But.... i would still check the numbers in your PBP and SP (especially the elevation) just to make sure there correct.  i'm also assuming in your Revit model everything is lining up :-).
Howard Munsell
