Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Rebar is Hidden
3 REPLIES 3
ahmed.galal
497 Views, 3 Replies
Rebar is Hidden
After exporting the model from revit i found that the rebar aren't appears in the navisworks 3D and it's hidden inside the concrete elements, how can i show the rebar in the navisworks
note:- the property (view as solid) in the revit is already checked before exporting to nwc.
3 REPLIES 3
Hi @ahmed.galal,
you can follow this tutorial to find out how to put a transparency to a material.
https://knowledge.autodesk.com/support/navisworks-products/learn-explore/caas/CloudHelp/cloudhelp/20...
Best
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Want to present in Infraworks? Vote this up!
Thank You Mr. Nicola, but unfortunately this solution didn't work with me.
Hi @ahmed.galal,
can you show us what you see?
Nicola
Rail Community
