After exporting the model from revit i found that the rebar aren't appears in the navisworks 3D and it's hidden inside the concrete elements, how can i show the rebar in the navisworks
note:- the property (view as solid) in the revit is already checked before exporting to nwc.
Hi @ahmed.galal,
you can follow this tutorial to find out how to put a transparency to a material.
Best
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Want to present in Infraworks? Vote this up!
