Quick Properties Shows Different Info Than Properties Window
cburgessYUD2V
Message 1 of 1
cburgessYUD2V
I've stumbled on something odd, and I'm hoping there is something easy I'm overlooking. I'm using Navisworks Manage 2022 and I found that the information given in the Quick Properties on at least a few instances shows different data than what is listed in the Properties window. See the attached picture to see what I mean. But the Quick Properties is giving me good usable info like pipe diameter, invert elevations and piping systems, but none of that shows in any of the tabs for the Properties window for this particular object. To be clear, I understand that Quick Properties will show less data than the Properties window, but how can it show more data than what the Properties window has?
I have set up a lot of info fields in the Quick Properties editor because I get models from a number of different sources and authoring programs, so there are some for AutoCAD and Civil 3D and Revit etc., but I don't see how I can be getting completely different information between Properties and Quick Properties for the same element. Is there a maybe setting to choose the tabs shown in the Properties window?
The below (and attached) picture shows each of the 4 Properties tabs for the highlighted pipe; see how none of them have the information that shows in the Quick Properties box (besides Item Name and Source File) :
Replies (0)
