Product Update: Navisworks Coordination Issues Add-In 5.0.0
Edit: Version 5.0.1 of the Navisworks Coordination Issues Add-In has been released
Version 5.0.0 of the Navisworks Coordination Issues Add-In has been released to the Autodesk Apps store, and on manage.autodesk.com.
Prerequisites
Please uninstall prior versions of the product before installing the new version.
Product Improvements
- General: Navisworks 2026 support
- General: Remove support for Navisworks 2020
- Connected: Display Model paths in Model selection screen
- Connected: Reposition/Move pushpin support for models loaded from Desktop Connector
- Connected: New Coordination tab on the Navisworks Home page, providing access to the Navisworks Coordination Issues Add-In.
- Issues: Support issue creation on NWD's loaded from Desktop Connector even when publishing has failed
- Issues: Clash Issue Syncing (Navisworks 2025 & 2026 only):
- When creating issues based on clashes from Clash Detective, the respective statuses are synced between the issue and the selected clashes within Navisworks, and also with the issue in Model Coordination.
- In Clash Detective users will now see a new column called Related Info which will display the status of the linked issue.
- Users have an additional option to Select Issue which will open the issues panel and select the linked clash.
- As the statuses used for clashes in Navisworks and issues in Model Coordination don't directly align, Model Coordination project administrators can specify how the two sets of statuses map against each other.
Stability and Defects
General fixes
- Issues: Pushpin location incorrect when using local NWF referencing NWD from desktop connector.
- Issues: Issues panel intermittently failing to load for Coordination spaces with 200+ models
- Connected: Fix Project RFI's, Submittals, or Forms external invalid links
Regards
Brett Parker
Navisworks Product Manager
