Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Problem with Liquid material texture scale
2 REPLIES 2
andyjg
338 Views, 2 Replies
Hi all,
I have a small issue that I would really appreciate some help with. I am trying to add an ocean type effect for a view of a ship I am putting together for work. I have added a very large but flat cylinder to the view that I can add a material to.
My problem is that when I add the material 'Tropical Blue' to the cylinder (or any other liquid material), the actual scale of the water texture is far too small to see from a distance. Only after I zoom right in can I see the actual texture of the water. Please can I have some help on this? It looks like I just need to increase the scale of the texture somehow but I can't figure out how. I am using Navisworks 2016 but also have the same issue on Navisworks 2017. See screenshots below.
The diameter of the 'ocean' is 1km. The ship is not in the view but is about 200m long.
Many thanks,
Joe
2 REPLIES 2
Have you ever found a solution to this issue? Having the same problem 5 years later and not a single solution to be found anywhere...
See my answer in THIS thread. Might be applicable for you too.
Louis
Please mention Revit version, especially when uploading Revit files.
Rail Community
