Point cloud visibility in viewpoint animations
Message 1 of 8
Is there a setting I am missing.   I am trying to do a fly through of a model containing solids and a point cloud, but when I export the animation, the resulting video only shows the solids.  The point cloud is not visible at all
Replies (7)
Message 2 of 8
dgorsman
No, that's correct.  The points are infinitely small with zero surface, so they cannot render with materials.  I've been able to render without materials (viewport, not Autodesk render) but the results are less than ideal from a presentation perspective because of the slight mismatches between the cloud and model, as well as the virtual transparency means the cloud won't hide anything "behind" the surfaces it represents.  I've had some success using a couple of techniques, one being "picture-in-picture" or "split-screen" with separate model and point cloud in each, the other being a stationary cross-fade transition between point cloud (no model) and model (no point cloud).
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 3 of 8
Ok, wish list I guess.   I started making videos out of recap now that you can bring the nwd into the realviews.   It looks good, but you have to jump from realview to realview, can't pan around.     Thanks
Message 4 of 8
Patrick_Aps_9121
No, that is not correct at all. I am able to create Xvid compressed video's from Navisworks with the Recap cloud attached.
I used viewpoints to create the video. In the selection tree, you can hide all scan positions of the Recap Project indivually. In the 1st viewpoint all scans were hidden, in the 2nd only one was unhidden and so on.
This way, I was able to let the cloud appear in the video.
Also Clipping boxes work in the Viewpoints that make up the Video.
also Walking trough works.
I used version 2015 to make the video.
Message 5 of 8
Ok, that's good news.  what were your settings in the export animation window?   Could you post a snip?
Message 6 of 8
Patrick_Aps_9121
I work with Simulate 2015 SP3
version 12.3.0..115750
Here are my Export Animation settings in a screenshot
I have installed Xvid 1.3.3
My Options -> File Readers -> ReCap are:
Voxels
500000
0 MB
100 % Density
Scale Interactive Point Size
Max Interactive Point Size: 8
No Lighting
On Publish Embed Xrefs: Fast Access.
Message 7 of 8
dgorsman
That's using the viewport renderer though - it doesn't work with the Autodesk renderer, so no materials, lighting, and so on.  I probably should have mentioned that earlier.  Smiley Sad
Message 8 of 8
Patrick_Aps_9121
That indeed could be a limitation. I'm not interested in materials and lighting, just in free space and clashes.
But it was not mentioned in the original post so maybe Jason does not need it either in his animation.
