Point Cloud in Simulate or Manage
darmarco
darmarco
Hi there Navis gurus
I only need to know if Simulate can import laser scanned point cloud files (I know Manage can).
Simulate is about 2.5 times cheaper (than Manage) and I don't need clash detection.
Anyone out there knows this?
Thanks!
alan.johnson7YLND
I found this  on the Autodesk Knowledge Network:
Using of .RCP point cloud in Navisworks like in ReCap
Autodesk Support
Oct 8, 2023
Issue:
Is it possible to load our laser scan (point cloud .RCP) into Navisworks and walk through the model and display the photorealistic scan images in Navisworks like in ReCap?
Solution:
Currently the following is possible in Navisworks:
alan.johnson7YLND
So reading that I would say yes you can bring in point cloud data (rcp) into Navisworks Simulate
alan.johnson7YLND
in fact if you go on the compare products for Manage and Simulate, it doesn't specifically mention point cloud data.
So I would take that as both can import point cloud data.
https://www.autodesk.com/products/navisworks/compare/compare-products
