Pipe bends are showing in wireframe in Naviswork 2025
Karthikeyan_Albion
Observer
Observer
Karthikeyan_Albion
Observer
Observer
We have created a piping model in Plant 3D and imported it into Navisworks Manage 2025. However, the pipe bends, flanges and fittings are not showing as solid but as wireframes, which was not the case when we used Manage 2023.
Kindly help us with a solution ASAP.
Earlier, there was an Object enabler (2023) to make these items solid. But even though we have the object enabler (2023), we still face the same issue. The latest version is not available for it yet.
alan.johnson7YLND
I believe Navisworks and the object enabler need to be the same version, so both 2025
Karthikeyan_Albion
Observer
Observer
Thank you. But, there is no object enabler available for the latest version of Autodesk Plant 3D. Anyway, it has been solved with the help of AutoDesk personnel.
