Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
PARAMETER MAPPING ISSUE FOR TYPE PARAMETERS
3 REPLIES 3
robertovalentino
331 Views, 3 Replies
Hi all,
it seems that in Navisworks 2023 you can not map type parameters to the elements you take off.
I was used to mapping from the "Revit Type" tab, parameters like "Description" and "type mark" to all my elements
In Navisworks 2023 the Type properties are on the node above in the selection tree, which is the grouping of all the items of that type and the mapping rule is not working for the type parameters.
any workarounds?
Thank you in advence
3 REPLIES 3
Hi ! Did you install the respectve  "NAvisworks NWC Export Utility"?
https://www.autodesk.com/products/navisworks/3d-viewers
I did, and I exported the file correctly
My problem is the mapping
I want to join the topic. Have the same issue, NWC export from Revit (with same settings) now places Revit Type parameters under "Type Custom"...
NavisExporter is the same as Navisworks (2023), settings are unchanged since last submission (which was working fine).
Rail Community
