Opening Revit .RVT files
roger.walkerV6YGZ
Observer Observer
Message 1 of 9
roger.walkerV6YGZ
Observer
Observer
This page says that Navisworks Freedom 2022 will open revit files but I can't get it to.
https://help.autodesk.com/view/NAV/2022/ENU/?guid=GUID-38E592D6-4EE1-462F-BC80-68890AA2597E
The file open dialog only show recap and DWF files.
Likewise the settings for "file readers" only shows these 2 options.
I do not have Revit, this is to view a revit model.
The online viewer will not open it (after several minutes of importing and processing it throws an error)
Roger
Replies (8)
Message 2 of 9
DarrenP
No it doesn’t that is the help for full Navisworks
Freedom doesn't open rvt files
Here is the help for freedom: https://help.autodesk.com/view/NAVFREE/2022/ENU/?guid=GUID-82273D46-50EB-42F1-A1BC-0F60DF68621D
DarrenP
Message 3 of 9
PatrickDavis20
What are you trying to accomplish?
If you want to open the Revit model just to view it, you have a couple of free options from Autodesk.
The first and easiest is using their viewer. https://viewer.autodesk.com/.
The second is using Revit. You can install Revit and use it without a license. That is the viewer mode. You will not be able to save or export anything (except exporting to Assemble), but you can view the model.
If you need to use the model in Navisworks, as the author of the model to create an NWC or DWF file that you can import.
Patrick Davis
Twitter
LinkedIn
Blog
Message 4 of 9
roger.walkerV6YGZ
Observer
Observer
As I said - the viewer doesn't work on the files I have.
An install of Revit is something I've asked the IT department for but not sure what their response will be.
Message 5 of 9
DarrenP
Who are you getting the file from?
What software do you have installed?
DarrenP
Message 6 of 9
roger.walkerV6YGZ
Observer
Observer
Architect, Navisworks Freedom
Message 7 of 9
DarrenP
Can the architect not convert the file for you?
DarrenP
Message 8 of 9
roger.walkerV6YGZ
Observer
Observer
I doubt they would.
Message 9 of 9
DarrenP
then you need to work with the Architect & get the correct file format for you to use
or get Revit installed on your computer or have someone else convert the file for you
DarrenP
