NWD files - looking for an example
MKH-VB
Message 1 of 9
MKH-VB
I have downloaded the navisworks freedom viewer, but it does not come with any demo files that I can view.  Can someone point me in the right direction so I can get a file to start learing the program. Thanks
MKH
mkh
Replies (8)
Message 2 of 9
lee.mullin
I have attached a basic model.
If you would like more models I suggest downloading the Navisworks Manage trial as this contains more models in the examples folder
http://www.autodesk.com/navisworks-trial
Lee Mullin
Construction Technical Specialist
Autodesk Ltd.
Message 3 of 9
MKH-VB
thanks very much.  I appreciate you.
MKH
mkh
Message 4 of 9
MKH-VB
can you tell me if I can go inside that structure, and if so, how do I get there (in navisworks freedom 2010)  Thanks
mkh
Message 5 of 9
lee.mullin
You can use the walk and fly tools to navigate inside the model, please ensure you have Collision switched off, more information about this can be found in the Help guide.
http://images.autodesk.com/adsk/files/autodesk_navisworks_freedom_2012_user_guide.pdf
Lee Mullin
Autodesk Ltd.
Message 6 of 9
I have been using this Gatehouse to create a 4D simulation for a project. Is it possible to get a Revit file of the gatehouse to add more detail to the model? I have been trying to use Navisworks switchback but this won't work.
Message 7 of 9
DarrenP
i have the autocad .dwg file
DarrenP
Message 8 of 9
 have you completed the 4d model? can you share it?
Message 9 of 9
Much appreciated!
