Need dos command in .bat file for Windows Scheduled Task Manager
Yogesh.Phalak
Yogesh.Phalak
While converting Smart3D extracted .vue file into .nwd file using navisworks simulate 2021, we need dos command which will help us to set different color for "Approval Status".Currently we have to open nwf file and need to do it manually as Select properties from Selection tree - Right click- Override Item- Override color.
Instead of manually can we set up in script?
If yes, please share that scipt.
PatrickDavis20
You might want to look at iConstruct. They have a tool called BIMFlow that allows you to automate tasks. These tasks can then be scheduled (via Windows Task Scheduler). BIM software for Autodesk® Navisworks® | iConstruct
Patrick Davis
Twitter
LinkedIn
Blog
