Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navisworks UI is a nightmare
2 REPLIES 2
tlesmeisterAQ42X
365 Views, 2 Replies
Invisible buttons in the Find Items Tree? a weird plus symbol that means "OR" (also inherently invisible...), the search function WITHIN the find items stinks (you cant type what you're looking for), half the time when you create a "search function" it will back-up a few spaces and remove what you currently tried to make part of your Search function. When it works, it works great. But my god it's a nightmare that doesn't play well in the sandbox.
Why does exporting Clash Tests from the Clash Detective window only export Search Sets? But you can export Clash Tests (simultaneously with Search/Selection Sets) from the Output Tab on the Ribbon. Why? Why are there 7 different ways to have the tests output certain types of information?
By the looks of forums, most of these issues are years (pushing a decade) old.
I had to put this under "Revit Products" because Navisworks isn't even in the menu.
I suggest the devs actually read forums for future updates of their products. Because obviously the devs don't actually use these products
Labels (1)
2 REPLIES 2
I am not sure there are any developers focused on Navisworks. They occasionally put out a patch, but if you want new functionality, then you need to look at iConstruct. Autodesk's development dollars are going into ACC and unfortunately not Navisworks.
Patrick Davis
Twitter
LinkedIn
Blog
v_jeske
in reply to: tlesmeisterAQ42X
It´s insanely unintuitive compared to it´s competitors
Rail Community
