Navisworks shows XREF colors from a DWG as gray, override does not take effect in Navisworks Simulate 2016. can you help me?
I am having the same problem, any solutions?
I know that under options you can change the display graphics system from "autodesk" to "basic", that will change the xref colors.
but it changes the background to all black.
Is there a way to do it without changing the background to black?
Under Options --> File Readers --> DWG/DWF --> Uncheck Convert Autodesk Material
This worked for my situation.... using AutoCAD 2018 and CadWorx 2018
