Navisworks Forum
Welcome to Autodeskā€™s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Showing results forĀ
Did you mean:Ā
Navisworks shows XREF colors from a DWG as gray, override does not take effect
4 REPLIES 4
1306 Views, 4 Replies
Navisworks shows XREF colors from a DWG as gray, override does not take effect in Navisworks Simulate 2016. can you help me?
4 REPLIES 4
I am having the same problem, any solutions?
I know that under options you can change the display graphics system from "autodesk" to "basic", that will change the xref colors.
but it changes the background to all black.
Is there a way to do it without changing the background to black?
You can also under options, uncheck Convert Autodesk Material.
That seemed to work for me.
dave.simmons.ext
Under Options --> File Readers --> DWG/DWF --> Uncheck Convert Autodesk Material
This worked for my situation.... using AutoCAD 2018 and CadWorx 2018
Your are right sir! Thanks
Unchecking Convert Materials, worked!
Rail Community
Ā
Ā
